April 13, 2022 at 8:18 am
kpuneet
Subscriber"* ERROR * CP = 5.719 TIME= 10:33:52
The normal of target element 8907999 is not consistent with the normal
of target element 8908048 in real set 55. Please use the ENORM
command to correct it."
Can anyone help me related to this error
April 13, 2022 at 9:56 amEmperor
utilisez vous ansys APDL?
April 13, 2022 at 11:32 amEmperor
Subscriberdo you use ansys APDL?
December 31, 2022 at 11:10 ambhagwantP
Ansys EmployeeDecember 31, 2022 at 11:13 ambhagwantP
Ansys EmployeeYou can locate solve.out or error file in solver files directory and see if you can find out any real ID mentioned over there for contact set (There issue could be lying for that contact pair).
What error do you get when trying to evaluate the contact tool?
December 31, 2022 at 11:14 ambhagwantP
Ansys EmployeeForgotten to mention solver files directory you can locate once you right click on solution tab in mechanical.
Viewing 5 reply threads- The topic ‘Enorm Syntax’ is closed to new replies.
3427
1057
1051
896
892
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
