TAGGED: ansys-workbench, error, mechanical, transient-structural, workbench
March 8, 2021 at 6:26 pm
CraigSneddon
SubscriberMarch 9, 2021 at 4:36 pmGovindan Nagappan
Ansys EmployeenCan you select all other system and export to a new archive?nSelect multiple systems by clicking on the first row(Static, Transient etc). Hold the CTRL key for selecting multiple systems. Right click and export systemnSee if it helpsnn
The black X's indicate that the data underlying the components could not be found. There should be a *.mechdb file for each static structural system. You can use View -> Files in WB project page to see list of associated files. You will see mechdb files missing(appears in red color). See if you have a copy of the project and if you can locate these filesn==========================nAnother option is to rebuild the project from existing mechdb files in the projectnCopy the *.mechdb file to a new locationnChange the extension to *.mechdatnIn a new WB project, try importing it using File -> Import (Importable mechanical database)n n
March 11, 2021 at 1:09 pmCraigSneddon
SubscriberThanks I have managed to export solved/working systems to a new project using second method. Thank you nViewing 2 reply threads- The topic ‘Engineering Data Issue’ is closed to new replies.
4678
1565
1386
1241
