Energy Equation Divergence ansys divergence
    • Issam EL KHADIRI
      Hello
      During the simulation the error appears to me
      For pressure–velocity coupling, a segregated solver was used with the SIMPLE algorithm. The second-order upwind scheme was used to discretize the convective terms in the governing equations.
      The residuals were set to 10−4 for continuity, 10−5 for momentum, and 10−6 for energy equations.
      The number of iterations per time step was set to 20.
      The time step size 0.001
      number of time steps 5000
      mesh: 500 000 element
      This is the geometry (heat sink TPMS) (Fluid: air, Solid: aluminum)
      What's the mesh quality like?
    • Issam EL KHADIRI
      Hellom
      Thank you for your answer,
      This is the Report quality:
      Mesh Quality:
      Minimum Orthogonal Quality =  3.24228e-07 cell 86742 on zone 6 (ID: 1279410 on partition: 2) at location ( 1.00402e-02  7.34195e-03  3.86050e-03)
      (To improve Orthogonal quality , use "Inverse Orthogonal Quality" in Fluent Meshing,
       where Inverse Orthogonal Quality = 1 - Orthogonal Quality)
      Warning: minimum Orthogonal Quality below 0.01.
      Maximum Aspect Ratio =  1.34494e+03 cell 296109 on zone 6 (ID: 1115234 on partition: 2) at location ( 5.03466e-02  1.06909e-03 -8.35610e-03)
      Fluent can try to improve the mesh quality via the TUI command
      /mesh/repair-improve/improve-quality
       Domain Extents:
         x-coordinate: min (m) = -9.000000e-02, max (m) = 1.500000e-01
         y-coordinate: min (m) = -1.000664e-02, max (m) = 1.000000e-02
         z-coordinate: min (m) = -1.000000e-02, max (m) = 1.050000e-02
       Volume statistics:
         minimum volume (m3): 8.992539e-16
         maximum volume (m3): 6.769667e-10
           total volume (m3): 9.907077e-05
       Face area statistics:
         minimum face area (m2): 7.985135e-11
         maximum face area (m2): 1.673634e-06
       Checking mesh.....................................
      Done.
    • Issam EL KHADIRI
      I reduced the mesh to 10 million elements, but the problem persists until now
      Yes, it's the mesh. Min ortho quality of 0.05 is considered to be poor quality, you're somewhat below that. Similarly aspect ratio has some leeway for inflation, but 1,300 is very high.
      Looking at the second image, check the walls bounding the flow that cut the structure don't have narrow gaps or crevices which then cause the skew cells.
    • Issam EL KHADIRI
      I reduced the meshing from half a million to 10 million elements to reduce the effect of meshing
      I also checked that the geometry does not have any gaps or crevices.
      But no change, the problem still exists
      Could the problem be somewhere other than the mesh or the geometry?
      And what did that do to the cell quality?
    • Issam EL KHADIRI
      The problem has been solved. You were right. There was a problem with the mesh.
      thank you for your help
    • Issam EL KHADIRI
      I have another problem with the results
      When I create pathlines for the air, it appears that it passes through the structure without being considered, as shown in Image 1
      Also, there is no change in air temperature as shown in pictures 2
      No turbulence appears.
      I used the SST K w for viscous
      That means you've managed to mesh both zones but not split the solid from the fluid: that may explain the improvement in cell quality.
    • Issam EL KHADIRI
      Sorry, I didn't understand how to split the solid from the fluid?
      I am working with a solid separated from the fluid, like the picture below
      Try subtract. Unless you really want to see the solid heat up you don't need it in the CFD model.
    • Issam EL KHADIRI
      I need to see the heating of the solid with the velocity of the fluid and show the turbulence
      OK, so you'll need to subtract and retain the solid and then share topology. The terms etc are covered in the tutorials, and I advise having a look at the various conjugate heat transfer tutorials/videos on the Ansys system.
    • Issam EL KHADIRI
      I think that the solid is separated from the fluid because I named each of them in the meshing stage along with naming the boundary conditions/regions. with contact surface
      You've got wall and wall shadow in Fluent and assigned the solid material to the metal part? If you have done that how are the pathlines going through the metal part?
Viewing 15 reply threads
  • The topic ‘Energy Equation Divergence ansys divergence’ is closed to new replies.
