September 24, 2024 at 12:28 pm
Kelsey O'Donnell
SubscriberI am having an issue creating an enclosure around multiple solid objects (around 700). I set the enclosure to be a certain size and after a while the enclosure appears to be created in the outline on the lefthand side of spaceclaim but in reality the box that I tried to create did not work. I have included screenshots of what I am trying to do.
September 24, 2024 at 12:50 pm
Forum ModeratorOdd. If you create the volume from sketch & pull what happens.Â
September 24, 2024 at 5:43 pm
Kelsey O'Donnell
SubscriberHi Rob, what do you mean by create the volume from sketch?
September 24, 2024 at 3:44 pm
Kelsey O'Donnell
SubscriberÂ
September 25, 2024 at 8:57 am
Forum ModeratorUse the sketch function to create a surface and then pull for the volume. Or create a bounding box in the CAD tool of choice. Something isn't working as expected and that could be due to the imported shapes.Â
6269
