Photonics
Photonics
Empty results in s-matrix
    • minusunny
      I tried s parameter sweep using lumerical FDTD and imported it to INTERCONNECT. When i tried running the simulation, i did not get any result. Also please see the s-parameter extraction settings from FDTD.
    • minusunny
      I aslo got this warning. Is it because my device is not symmetrical?
    • GWANG
      Hi minusunny,
      Thank you for the post. The warning doesn't block the s-parameter element. We will need to see the simulation file and s-parameter file to debug this.
  • The topic ‘Empty results in s-matrix’ is closed to new replies.
