Empty Material Assignment List, also no default assignment [Ansys Mechanical E]
    • michal.smalera
      I am trying to assign material to some geometries, but the pop-up list shows empty.
      How to repair this?
    • erik.kostson
      Hi
      First I would close mechanical, and go to Workbench project schematic, and the Engineering data in your system and define some materials – then see if they show up and you can select them inside Mechanical.
      If the above does not work see this:
      https://innovationspace.ansys.com/knowledge/forums/topic/materials-not-visible-or-gray-area-around-materials-pop-up-menu-window/
      Finally if none of the above works, please contact your channel partner so they can look at your installation and help.
      All the best
      Erik
    • michal.smalera
      I got the extra materials in Workbench.
      I was working on a laptop with 2 external screens. I disconnected them, restarted Mechanical and Workbench and it works correctly now.
      Thank you!
