January 4, 2019 at 2:58 pm
jdiaz
SubscriberBased on an infinite array simulation (aka unit cell), HFSS allows to calculate the embedded element pattern with a desired resolution established on the Master/Slave boundary conditions. For example, a microstrip patch antenna can be modeled on a square unit cell that lies on the XY plane with a resolution of 5 degrees (i.e., theta from 0 to 90 degrees every 5 degrees and phi from 0 to 180 degrees every 5 degrees). This model yields 1369 points of interest.
Now, to extract this data, I wrote a Python script that populates every point on a table using the "add trace command". The issue that I find is that it takes the software too much time to complete this table. My resources are a 16 core 2.4 GHz processor and 64 GB of RAM. The code has been running for 2 days and it has done only 524 out of 1369 iterations.
Now, my question is: is there a more efficient way of extracting the embedded element patterns of a unit cell?
Before, I have tried instead of making a big table, exporting each angle as a table and it takes about the same time.
- The topic ‘Embedded Element Patterns of an Array’ is closed to new replies.
3597
1243
1092
1068
953
