August 2, 2018 at 4:18 pm
cherishbauer
SubscriberI have installed the ansys workbench and electromagnetics packages and linked them. However, while most of the other emag executables seem to be working, I cannot seem to find or run HFSS. I am working with an academic research license. There do seem to be some executables related to HFSS in the folders, but not the main program. Is there another package I need to install for this to function correctly?
August 2, 2018 at 5:16 pm
tsiriaks
Ansys EmployeeHi cherishbauer,
HFSS and other Electronics/Electromagnetics products have been combined into one suite that's called ANSYS Electronics Desktop.
You should see this shortcut in Windows start menu.
If you can't find it, you can launch it by command line (change path for your installation and version, accordingly)
"C:Program FilesAnsysEMAnsysEM19.1Win64reg_ansysedt.exe" -shortcut
Thank you,
Win
August 13, 2018 at 2:56 pm
cherishbauer
SubscriberThank you!
- The topic ‘Emag installation – HFSS missing’ is closed to new replies.
3882
1414
1241
1118
1015
