Photonics
Photonics
elements in the Temperature monitor
    • somnath.paul
      What is the difference between the elements and IDs in the heat Monitor? For example, temperature.elements give a N:3 Matrix, what is the info that matrix contains?
    • Guilin Sun
      Element is the asic mesh in finite element meshing;
      ID is the identification for each element.
      the N:3 matric contains the meshing information and the result, for the unstructured data. You will need to interpolate it into rectilinlinear data. Please refer to this link  https://optics.ansys.com/hc/en-us/articles/360034405774-interptri-Script-command
  • The topic ‘elements in the Temperature monitor’ is closed to new replies.
