March 3, 2024 at 11:23 pm
Eric Schimanowsk
SubscriberHello, I would like to know how I can access the volume of each finite element in the USERMAT.
March 4, 2024 at 2:30 pm
David Weed
Ansys EmployeeHi,
The following code will give you the element volume fraction (volume per integration point):
DOUBLE PRECISION vect2(1)
INTEGER v_numv_num = 1Âprint*,'element num',elemIdprint*,'int point num',kDomIntPtcall get_ElmData ('EJAC',elemId, kDomIntPt,v_num,vect2)print*,'vect2 value',vect2 -
March 5, 2024 at 8:18 pm
Eric Schimanowsk
SubscriberHello! Thank you for the response! From what I understood, with this code I would have the fraction of the volume of the element that each integration point represents. But I would like to know the total volume of the element in volume unit in USERMAT.
March 24, 2024 at 3:17 am
Eric Schimanowsk
SubscriberHi, I still need help on the topic mentioned. Can anyone help me?
March 26, 2024 at 4:28 pm
David Weed
Ansys EmployeeHi Eric,
If you add all of the contributions from the integration points, then you should get the total volume of the element. e.g., this is the print out of a 2x2x2 hex element with 8 integration points (which we would expect the volume to be 8 units^3):
element num          1
 int point num          1
 vect2 value 0.999999999999100   Â
 element num          1
 int point num          2
 element num          1
 int point num          3
 element num          1
 int point num          4
 element num          1
 int point num          5
 element num          1
 int point num          6
 element num          1
 int point num          7
 element num          1
 int point num          8
 vect2 value 0.999999999999100 -
April 12, 2024 at 4:16 am
Eric Schimanowsk
SubscriberThanks for the response, but now a message is appearing when I use this code. "No material record exists at element 0, material point 0 for EJAC. Please send the data leading to this operation to your technical support provider, as this will allow ANSYS, Inc to improve the program."
April 15, 2024 at 2:14 pm
David Weed
Ansys EmployeeHi,
Can you let me know which version of ANSYS you are in and also which IFORT compiler and/or MS VS version you have installed? If in Linux, which GCC version?
April 15, 2024 at 9:00 pm
Eric Schimanowsk
SubscriberHi,
Thank you for your help.
ANSYS 2021 R2 version. Compiler Intel OneAPI, and VS 2019.
April 16, 2024 at 2:32 pm
David Weed
Ansys EmployeeHello,
According to the documentation, we only support these software versions for v212:
Microsoft Visual Studio Professional 2017 Version 15.0 (including the MS C++ compiler)
Intel C++ 2019.3.203 and Intel Visual FORTRAN 2019.3.203 compilers
So this may ultimately be a software compatibility issue. Please see if you can obtain these versions.
May 4, 2024 at 2:27 am
Eric Shimanowski
SubscriberHello,
I would really like to thank you for your help. I needed to access it through another account, but I'm still the same user who asked the initial question. The code is working properly and calculating the volume well for SOLID186 quadratic elements, but in the case of tetrahedral elements the calculated volume is incorrect. Any ideas on how we can get around this situation?
- The topic ‘Element volume in USERMAT’ is closed to new replies.
5654
1890
1414
1304
