Element type 1 is not the same shape as FLUID220
    • seckin
      Hi
      I am trying to simulate underwater modal analysis. But i have a problem which is "Element type 1 is not the same shape as FLUID220"
      What is the problem and how can i solve the issue?
      The 2 below are my inputs as command
      Best Regards
    • Rohith Patchigolla
      Hello Seckin,
      From element documentation for FLUID220 and FLUID221 in ANSYS help, you can see that FLUID220 is a 20-node hex where as FLUID221 is a 10-node tet.
      This error means that you are trying to switch a tet (SOLID187) to a hex (FLUID220).
      Please check what kind of elements the body contains. If it contains only tets, change et,matid,220 to et,matid,221
      Hope this helps.
      Best regards,
      Rohith
  • The topic ‘Element type 1 is not the same shape as FLUID220’ is closed to new replies.
