May 4, 2019 at 11:25 am
May 14, 2019 at 5:11 pm
Sandeep Medikonda
Ansys EmployeeIt's hard to debug without seeing the mesh or looking at what kind of analysis you are doing.
One thing you can try if you are using v19 or above is to click the 'M' key on your keyboard and see where these elements are? Are they part of the physical mesh/model? You can also click on Show Warnings/Error button and identify the offending object.
There are very good discussions with Peter on Honecomb structure analysis in the community that you can refer to:
- The topic ‘Element Size Zero Problem’ is closed to new replies.
1829
1387
1248
