TAGGED: ansys-student, cfd, fluent, mesh-generation, meshing
March 5, 2021 at 1:54 am
VerdeLeone07
SubscriberHi,I have been trying to set my element size smaller than 0.001 and it doe s not work and when I am monitoring the usage of my CPU it was using only 20% (I don't know if the CPU is the reason). I have tried all the following element sizes: 0.0001/ 0.0009/ 0.00095/ 0.00098/ 0.00099!! and it doesn't work. My laptop has 16 GB RAM i7 10th generation CPU. so basically I want to have a mesh size of 0.0001. Does anyone have any suggestions ??nThanks. n -
March 5, 2021 at 9:25 am
Keyur Kanade
Ansys EmployeeWith 1GB RAM, you can approximately generate around 3M cells. But with student version the cell limit is 512K. nPlease use some coarse size first and check what is cell count. nPlease go through help manual for more details nRegards,nKeyurnHow to access Ansys Online Help DocumentnHow to show full resolution imagenGuidelines on the Student CommunitynHow to use Google to search within Ansys Student Communityn
- The topic ‘Element Size in Fluent Student version’ is closed to new replies.
Ansys Innovation Space
1188
1076
1063
952
