Element shape checking is currently inactive. Issue SHPP,ON or SHPP,WARN to reactivate, if desired.
    • Jayakrishna
       Dear all
      I am using ANSYS19 R2.
      An unknown errors came
      1. "Element shape checking is currently inactive.  Issue SHPP,ON or  SHPP,WARN to reactivate, if desired."
      2. Material number 10 (used by element 7242) should normally have at least one MP or one TB type command associated with it.  Output of energy by material may not be available.
      Heartful thanks to any kind of help and suggestions.
      These are not errors, they are warnings. These warnings can be ignored.
    • Jayakrishna
      sorry for specifying as errors.
      Because of those warnings, I am unable to run the simulation further.
      It will be helpful if i know the reason for those warnings.
      If you have any information, please share which will help me to find any other mistakes in my simulation.
      Thanks for responding.
      You have an unknown error, so you have to look in the Solution Output for a possible reason.  Those warnings have nothing to do with the error.
      Click on the Solution Information folder and in the Details window, set the field to Solution Output.
    • haisu liao
      maybe you should change your core number.Solve, in the toolbar, there is a core number, click on the lower right corner to manually allocate arithmetic RAM
    • Durga Parajuli
      I got the same warning and could not run the program. In the solution output, I got the following error.
      The /CONFIG,NOELDB command is not valid in a Distributed ANSYS
       solution.  Command is ignored.
      Thank you for the help in advance.
Viewing 5 reply threads
  • The topic ‘Element shape checking is currently inactive. Issue SHPP,ON or SHPP,WARN to reactivate, if desired.’ is closed to new replies.
