October 25, 2019 at 6:33 am
October 25, 2019 at 10:56 am
Forum ModeratorWhich models are you using in Fluent? You may need to track min/max values of x, y & z on a surface: points in Fluent don't move.
October 28, 2019 at 1:01 am
SaurabhD
SubscriberHello Sir,
I am using Multiphase model (VOF).
What do you mean by points in fluent don't move?
Could you please elaborate on any method of calculating the velocities of the specific points.
I have access to Ansys Learning Hub too so if you have any material in there, even that might help.
October 28, 2019 at 12:06 pm
Forum ModeratorIf you create a point in Fluent it's fixed at the x, y, z position you defined. If the surface is moving or it's a VOF bubble you may need to track position of the isosurface of volume fraction.
Read up on monitor points to track the velocity with time, you'll find several examples of these for points/surfaces in the Fluent tutorials.
October 28, 2019 at 5:42 pm
SaurabhD
SubscriberOkay, Sir. I'll go through them and post if I come across any difficulty. Thank You!
October 29, 2019 at 10:30 pm
SaurabhD
SubscriberHello,
If not using VOF, is there any other way I can get the velocities of the specified points? I need to track the movement of the droplet with time.
Should I use CFX instead of Fluent?
October 30, 2019 at 11:39 am
Forum ModeratorWhat model are you using for the droplet motion? I think CFX has the same issue, so no benefit using it.
November 2, 2019 at 9:31 pm
SaurabhD
SubscriberOkay.
I had created the droplet using "Region" and specifying a "Spherical" coordinates at the desired location.
I have also tried drawing sphere on "Space Claim" and during meshing, I defined the sphere as "Fluid". Later, after initialization, I patched the sphere with fluid (Liquid) with VOF = 1.
Can I use Discrete Phase Model to track the fluid particle?
The main motive of the project lies in tracking the motion of certain particles of moving Fluid (Liquid). Could you suggest me any way of doing that?
November 4, 2019 at 1:56 pm
Forum ModeratorRead through VOF, Eulerian and DPM models in the Fluent User's and Theory Guides. This will give you an idea of the model numerics, and limitations. Bearing those in mind, explain exactly what you're trying to figure out.
- The topic ‘Element Selection – Fluent’ is closed to new replies.
- How do I get my hands on Ansys Rocky DEM
- Non-Intersected faces found for matching interface periodic-walls
- Script Error
- convergence issue for transonic flow
- Running ANSYS Fluent on a HPC Cluster
- Point exception in erosion calculation
- Errors with multi-connected bodies using AQWA
1992
896
599
591
418
