July 20, 2020 at 5:53 pm
July 20, 2020 at 7:19 pm
July 20, 2020 at 7:58 pm
July 24, 2020 at 12:59 pm
Guojz16
SubscriberHello
I'm interested about it. Would you mind give me the command? Thank you. I want to export many deformations datas of a lot of points orienting Z axis of a local coordinate system. I don't know what command I can use.
July 25, 2020 at 1:17 am
peteroznewman
SubscriberOpen ANSYS Help, go to Mechanical APDL > Command Reference and read the ESYS command.
That has some useful information. I used it to set the randomly oriented element triads in the post I linked to above, to a global or defined csys.
You need to set it to the I-J direction of the element, but only if the elements were meshed so that the I-J direction is uniform.
I can't help you more that this. Maybe some ANSYS staff can give you more help.
Viewing 4 reply threads
- The topic ‘Element orientation in 2D Axisymmetric model’ is closed to new replies.
1587
1386
1242
