September 11, 2024 at 6:01 pm
GUICAD
SubscriberHello
Is it possible to choose the order element of mesh in Refine?
Thanks,
September 12, 2024 at 6:25 am
Devendra Badgujar
Forum ModeratorHello,Â
Currently this is not possible in Discovery. You can refer this Mesh Evaluation (ansys.com) & How to check mesh quality in Discovery Refine Stage - Ansys Knowledge to monitor mesh statistics evaluate mesh quality.
DevendraÂ
September 12, 2024 at 8:07 am
GUICAD
SubscriberHello,
Which is used by default, linear or quadratic ?
Thanks,
September 13, 2024 at 6:41 am
Devendra Badgujar
For structural analysis we always use higher-order elements in Refine. If you check the structural mesh in Refine, you can see that the element edges are curved, .i.e. the elements are quadratic.
Regards,Â
Devendra Â
September 19, 2024 at 4:52 am
Viewing 4 reply threads
- Add-in Error Excel
- Fileformats
- Discovery 2025r2 failed to initialize
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
1495
1386
1209
