April 15, 2023 at 6:06 pm
Awlad
SubscriberDear ANSYS Users:
I am using "beam3" element to solve a 3D beam. I am getting an error message saying that "Element Has Zero Length". I am chaning the element size and node merging. But it did not work. I am also attaching my APDL code. Is there anyone who can help me to solve this problem? Thanks,
Awlad.
!! APDL Code:
fini
/clear
/title, Beam Problem "Exercise # 4.25"
/prep7
!! Make model first
!! Define Keypoints
k,1,0,0
k,2,10*12,0 Â Â Â Â !! x=10 feet
k,3,10*12,0,5*12 Â Â !! x=10 feet, y=0 and z = 5 feet!! Create Lines
L,1,2 Â Â !! L1
L,2,3 Â Â !! L2/pnum,line,1
Lplot!! element type
et,1,3!! Real constant
!! Section, W18 x 35 beamA=10.3 Â Â !! in^2
I=510 Â Â !! in^4
D=17.7 Â Â !! inr,1,A,I,D
!! material, steel
mp,ex,1,30e6
mp,prxy,1,0.3!! Make FE model
esize,1 Â Â Â Â !! Element size = 1 inch!! Recall Proper ID Numbers
type,1
real,1
mat,1Lmesh,All
elist!! BC
dk,1,all,0!! External load
fk,3,fy,-1000
fk,3,fx,500
fini
alls/solu
solve
fini -
April 17, 2023 at 1:44 pm
Chandra Sekaran
Ansys EmployeeBEAM3 is a 2D element (ux,uy,rotz dof) and MUST be in X-Y plane. The above input is in X-Z plane. May be you can switch to X-Y plane or switch the element type to Beam188 or Beam4.
mrife
Ansys EmployeeHi Awlad
Beam3 is a 2D beam that should be in the global XY plane only (it has X & Y translation and ROTZ degrees of freedom). Perhaps you mean to use Beam4 which is a 3D beam element.
Also, why are you using an undocumented element type? Â
Mike
April 27, 2023 at 3:39 am
Awlad
SubscriberThank You. It solved my problem.
Awlad.
- The topic ‘Element Has Zero Length’ is closed to new replies.
3767
1333
1173
1090
1014
