February 23, 2023 at 10:16 pm
Francisco Donda
SubscriberHi all, could you please help me with an explicit analysis? Im trying to approve an A36 structure for a dropped object analysis. The problem here is that the object is passing through it. It seems that the elements are "dying" after reaching some level of strain, could it be some type of auto ekill? If so, how to turn it off?
February 23, 2023 at 10:18 pm
February 24, 2023 at 12:51 am
peteroznewman
SubscriberClick on Analysis Settings and in the Details window, look at the settings under Erosion Controls. The default settings are shown below.
Erosion is the automatic removal of elements during the analysis that have exceeded the thresholds in this section.
The default setting has erosion when the strain exceeds 150% (1.5) but you can turn that off by setting Yes to No.If you define Material Failure limits in Engineering Data, then you can turn that on in this panel.
I also show the Output Controls because the Result Number of Points is a setting I always change on any new analysis because 20 is way too few output frames. A better number here is somewhere between 200 and 2000, the bigger number for when you are uncertian how long the impact event will last and it gives you enough frames so you can see something if it turns out to be a very brief time relative to the End Time you set.
February 27, 2023 at 9:36 pm
Francisco Donda
SubscriberHi peteroznewman, Thank you for your help but Im still facing some issues, could you please give me a hand?
The analysis is currently with 9e-3s at end time giving enough time for the project to clash with frame (this is taking 25e-6s). Looking at the total deformation and equivalent stress It is shown some deformation of the frame but at the directional velocity of projectile there inst a big change. Going to Energy Summary and Energy conservation all curves are pretty much stable. Does this means the impact is not being read? Not sure what is the problem here.
Thank you!
February 27, 2023 at 10:00 pm
peteroznewman
SubscriberHi Francisco, you can see that the impact is present because the sheet metal is bending at the impact site. What is the diameter of the projectile? What is the mass of the projectile? What is the impact velocity? What is the wall thickness of the sheet metal?Â
February 28, 2023 at 11:02 am
Francisco Donda
SubscriberHi Peteroz, I am following normative requirements of 5 kJ on the impact. To meet this Im using a 616.54 kg projectile with 100 mm (also a normative requirement), velocity of 4 m/s and wall thickness of 12.5 mm with material A36.
My main concern is that I expected a energy summary showning a cross point between Internal energy and kinetic energy which I was reading as impact moment (added an example below), dont know if this interpretation is mistaken.
February 28, 2023 at 11:43 am
peteroznewman
SubscriberThe example you show is the Energy Summary, but the chart you ask about is Energy Conservation. Please show the Energy Summary for your model.
February 28, 2023 at 2:03 pm
- The topic ‘Element failure – Explicit analysis’ is closed to new replies.
5664
1890
1419
1304
