TAGGED: ansys-apdl, ansys-mechanical-apdl, ansysapdl, apdl, apdl-code-in-workbench, apdl-coding, apdl-command, convergence, Convergence-Failure, convergence-issue, convergence-problem, mesh-elements, mesh-nodes, mesh-problem, Mesh-Updating, meshing, node, nodes-problem, quadliteral-mesh, Remesh, updating-mesh
April 1, 2024 at 5:47 pm
Adeleine Cabrera
SubscriberHi. I got an error stated above. There seems to be a problem with my APDL code. I'm trying to use SOLID65 and define stress and strain for every temperature. I have also tried to input "AMESH" above "/sol" but it didn't work. The mesh is already a tetrahedron linear mesh. I have tried to supress the APDL code and the analysis worked so, the problem really is on the APDL Code. But, I can't spot the error. Kindly help me on this. Thank you.
Here's what the APDL Command contains:/PREP7
solid65_matid = 9996
MPTEMP,1,20,200,400,600,800,900
MPDATA,EX,solid65_matid,1,12379.7911,5463.276115,2636.625645,747.8055365,336.5124914,186.9513841
MPDATA,PRXY,solid65_matid,1,0.2,0.2,0.2,0.2,0.2,0.2
TB,MELAS,solid65_matid,10,6
TBTEMP,20
TBPT,,0.0004999, 6.1884
TBPT,,0.0009995, 12.0469
TBPT,,0.0014989, 16.8393
TBPT,,0.0019980, 19.8166
TBPT,,0.0024969, 20.7518
TBTEMP,200
TBPT,,0.0010994, 6.0063
TBPT,,0.0021976, 11.6995
TBPT,,0.0032946, 16.3635
TBPT,,0.0043903, 19.2682
TBPT,,0.0054849, 20.1894
TBTEMP,400
TBPT,,0.0019980, 5.2680
TBPT,,0.0039920, 10.2706
TBPT,,0.0059821, 14.3777
TBPT,,0.0079682, 16.9450
TBPT,,0.0099503, 17.7710
TBTEMP,600
TBPT,,0.0049875, 3.7297
TBPT,,0.0099503, 7.2931
TBPT,,0.0148886, 10.2398
TBPT,,0.0198026, 12.1036
TBPT,,0.0246926, 12.7305
TBTEMP,800
TBPT,,0.0049875, 1.6784
TBPT,,0.0099503, 3.2819
TBPT,,0.0148886, 4.6079
TBPT,,0.0198026, 5.4466
TBPT,,0.0246926, 5.7287
TBTEMP,900
TBPT,,0.0049875, 0.9324
TBPT,,0.0099503, 1.8233
TBPT,,0.0148886, 2.5599
TBPT,,0.0198026, 3.0259
TBPT,,0.0246926, 3.1826
TB,CONC,solid65_matid,1,9,Â
TBTEMP,,
TBDATA,,0.3,1, 3.59Â ,-1,0,0
ET,solid65_matid,SOLID65
KEYOPT,solid65_matid,1,1
CMSEL,S,NM_Con,ELEMÂ Â Â Â Â Â Â Â Â Â Â Â
EMODIF,ALL,TYPE,solid65_matid,Â
EMODIF,ALL,MAT,solid65_matid,
ALLSEL,ALL
/SOLU
I've tried to separate the code for modifying materials and type. Only modifying the type seems to get the error stated above while modifying the materials continued the analysis but there is a convergence error (stated below is the error) that stopped the analysis.
"Solution not converged at time 7.2 (load step 1 substep 1).           Â
 Run terminated."
Your answer would be a great help. -
April 2, 2024 at 1:54 pm
Govindan Nagappan
Ansys EmployeeLooks like you are using an undocumented element. Do you know the order in which the nodes are written for solid65. Since you are changing the type from another solid element, see if this solid element also uses the same node sequence. Otherwise emodif will result in error.
For example: see solid 70. You can see the node sequence I, J,K,L...
Element is defined using this sequence
Or check the element definition in the input file and see if it is properly written in the input file. If there is mesh corruption, that could also cause this,Â
April 2, 2024 at 2:03 pm
Adeleine Cabrera
SubscriberHi. I actually did Transient Thermal Analysis first and I used that SOLID70 for the solid. I transferred the results of the transient thermal analysis to transient structural analysis. Hence, for transient structural analysis, I need to make the solid to have SOLID65, which has the same number of nodes as SOLID70. SOLID70 worked for the transient thermal analysis so, I don't get why SOLID65 doesn't work for Transient Structural Analysis.
April 2, 2024 at 2:09 pm
April 2, 2024 at 3:18 pm
Adeleine Cabrera
SubscriberHi. It still says the element has an undefined number 0. I want to use SOLID65 because the solid is a reinforced concrete. I tried ETCG,TTS alone but it just resulted to SOLID185 and SOLID285.
April 2, 2024 at 3:00 pm
Adeleine Cabrera
July 25, 2024 at 9:41 pm
Ivana Drobnjak
SubscriberDid you find the solution? I have the same problem. Thank you. I want to change SOLID 185 to CPT 215.
- The topic ‘Element 30 has an undefined node number 0’ is closed to new replies.
5794
