TAGGED: current, joule-heating, mechanical, thermoelectric
December 16, 2021 at 10:17 am
m_gonser
SubscriberHello together,
i just spend a lot of time to model a battery in steady-state thermal-electric module on Ansys Mechanical and validated my model with experimental data.
Now i want to do a transient simulation where my current is changing. As joule heating plays a major role in my thermal behaviour, how can i do a transient simulation including the joule heating? Coupling my models? Import the Joule heat as heat generation, depending on my current?
I am a beginner to mechanical and have almost no experience in using APDL.
I hope someone can help me out! Thanks already!
December 16, 2021 at 10:24 amErKo
Ansys EmployeeHi
The easiest is to run your current model (steady-state thermal-electric), and just use an apdl command snippet to change/convert it (steady-state thermal-electric) to a transient analysis.
Below is a discussion that gives the commands on how to do that (run transient).
All the best
Erik
July 7, 2023 at 7:55 pm
dgonzaleznino
SubscriberGreetings!
I am interested on doing something similar. Where I can find this discussion?
Thanks,
January 6, 2022 at 8:35 amm_gonser
SubscriberThank you !
Thats exactly what i was looking for!
January 6, 2022 at 9:30 amErKo
Ansys EmployeeGlad to help.
All the best.
Erik
July 8, 2023 at 7:18 amErKo
Ansys EmployeeHi
We should use the native system now called coupled field transient with thermal and electric (conduction) physics.Â
See here for more info:
Coupled Field Analysis Types (ansys.com)
Or search the online Ansys help for coupled field analysis types.
Thank you
Erik
Viewing 4 reply threads- The topic ‘Electro-thermal model in transient simulation’ is closed to new replies.
5969
1307
