June 4, 2019 at 7:42 pm
dd17
SubscriberI am performing a static structural analysis of a sample material made of steel.
At standard temperature, steel's modulus is about E=2E+11 Pa. At elevated temperatures, the steel modulus of elasticity should decrease. Does ANSYS static structural module account for the reduction in the modulus of elasticity if I specify the thermal condition of the material to be at an elevated temperature? Â
June 5, 2019 at 7:40 am
jj77
SubscriberSee this link for more details on how to do that (especially slide nr 12):
https://caeai.com/sites/default/files/Material_Property_Data.pdf
- The topic ‘Elastic modulus properties as a function of temperature?’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
1467
