March 22, 2024 at 5:46 am
Umer Farooq
SubscriberHi all
I am trying to implement High Impedance Surface Metasurface Unit Cell using HFSS Eigen Mode Solver. Can you please tell what should I keep the Min Frequency Value in Solution Setup?
I am designing at 10 GHz. -
March 26, 2024 at 12:59 pm
Praneeth Munaga
Ansys EmployeeHi Umer,
Thank you for reaching out to the Ansys learning forum.
Generally, the unit cell analysis is done using the Floquet port excitation along with coupled boundaries in HFSS. You can find an example design named "Split_Ring_Resonator" available under the "Open Examples" which demonstrates the implementation of the same.Â
Best regards,
Praneeth.Â
- The topic ‘Eigen Mode Solver HFSS’ is closed to new replies.
1332
1152
