Effects of gravity ridiculously low
    • Antonin HIPPOLYTE
      Hello everyone,
      I tried to simulate gravity driven fluid flow in Fluent (gravity=9.8m.s^-2, water, 1m heigh, two outlets with same pressure) and the velocity resulting was 12 orders of magnitude too low.
      So I closed the outlets to see the hydrostatic pressure profile and it is also ridiculously low.
      Further I have a good hydrostatic profile (10^4 Pa of difference for one meter of water) with a gravity of 10^14 m/s^2.
      Do you have any idea why the effects of gravity exist but are far too weak ?
      Thank you in advance
      https://ansyshelp.ansys.com/account/Secured?returnurl=/Views/Secured/corp/v231/en/flu_ug/flu_ug_bcs_sec_bound_cond.html%23flu_ug_sec_pinlet_hydrostatic
      Also, please confirm what material is set in the fluid cell zone panel.
    • Antonin HIPPOLYTE
      Thank you for your answer but I'm sorry, it seems I don't have acces to this link.
      As I said, the material I use is water but, even with the lightest gas, a pressure of 1e-11 Pa is unexplainable.
      Click on Help in Fluent. Then paste the link into the browser.
      Please post a screen grab of the cell zone panel: many copy water into the available materials and then don't get them into the model. Easy error, hence me wanting to confirm.
    • Antonin HIPPOLYTE
      Thank you for the help.
      First, as you can see I use water in the cell zone panel.
      Then, thank you for the link, I understood the plotted pressure doesn't contains the hydrostatic term. But in that case I have two questions :
      • Even if it is very low I have still a hydrostatic pressure profile, and it is too clear to be a machine zero error. And multiplying the gravity by 10^13 I obtain the right hydrostatic profile. Why ?
      • Why is the velocity so low ? you see I have water but even with air it should be greater.
      What operating density did you set?
    • Antonin HIPPOLYTE
      Thank you very much, I didn't know about operating density and I had the one by default.
      With an operating density of 1000kg/m^3 I have a much better pressure profile yet still not the 10000 Pa we would expect from 1m of water.
      Keep reading! Also note, water in Fluent is 998.?? kg/m3 unless you altered it.
    • Antonin HIPPOLYTE
      I wrote 1000 because it was faster but I'm not sure a difference of density of 0.2% would induce a pressure gradient 1000 times too low...
      Read the section covering (rho - rho_operating).
Viewing 9 reply threads
  • The topic ‘Effects of gravity ridiculously low’ is closed to new replies.
