October 27, 2025 at 10:52 pm
stefanov
SubscriberHello, suppose we have to simulate a dipole antenna that is a height lambda/100 away from the top of the half-space boundary (thus the dipole itself is in free space and lambda is the operating frequency). Suppose the halfspace is composed of a relative permittivity of ~4 and loss tangent of 0.01. Is the only way to simulate this in the FEM-solver to create an incredibly large slab of the dielectric material? We were going to try to use the FE-BI boundary but we still require some distance between the antenna and the boundary, thus we couldn't put it between the antenna and the slab itself. Is there an easier/less memory requirement way to simulate this that doesn't use the pure IE mode (thus we can't use the half-space boundary available in those simulation types)?
Thank you for your time!
- Lumped Port Deembed
 - HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
 - Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
 - Hfss 3D pcb via capped and filled with epoxy
 - AEDT Natural Convection with default correlation is failing solver initializatio
 - STL Import Errors in HFSS After Cleaning in SpaceClaim
 - Calc Error in Field Calculator after PyAEDT Analyze
 - import file autocad 3d
 - Co-simulation in Q3D, Icepak – meshing problem
                        4167
                        1487
                        1363
                        1194
