March 13, 2023 at 8:38 am
Duncan Gibbons
SubscriberHi all,
I am performing a fatigue life analysis in ansys mechanical (static strcutural) on a bracket. I get a lower life estimate at only one mesh vertex (pic attached). Is this due to the edges of the CAD model and/or a poorly meshed body? It is located at the interface between a flat surface and a curved fillet.
Thanks,
March 14, 2023 at 2:26 pm
danielshaw
Ansys EmployeeThe Mechanical Fatigue Tool (FT) uses the raw nodal stresses to predict the fatigue life. If you have a local "hot spot" in the model (for whatever reason - bad mesh, stress singularity, etc.), the FT will use that local stress in the fatigue calculations. You probably should remove that hot spot from the FE model. If removing it is impractical, then you should probably remove that node(s) from the fatigue calculations by scoping the results to a Named Selection that does not contain that node(s).
March 16, 2023 at 3:26 pm
Duncan Gibbons
SubscriberThanks for the insight!
March 16, 2023 at 3:31 pm
danielshaw
Ansys EmployeeYou're welcome.
- The topic ‘Effect of design nurbs and meshing on Fatigue life in static structural analysis’ is closed to new replies.
- Contact stiffness too big
- Test post on Forum – LLM response – SC
- 13-Node Pyramid Element Shape Function
- Element Birth and Death
- Python-Script to Export all Children of a Solution Tree
4492
1494
1376
1209
