3D Design
3D Design
Editing a sketch
    • m_youssef91
      Can I edit a sketch in the Spaceclaim after converting it to solid? If yes, could you please tell me how?
      There is no sketch after it becomes a solid. You can pull the face of the solid to change the shape using the Pull tool.
    • m_youssef91
      So if I want to change a radius or any dimension on the model I should redraw it from the beginning?
      In SpaceClaim, on the Design tab, there is a button on the ribbon called Pull. Click that (or type P on the keyboard), then click on the cylindrical face. An arrow and a dimension will pop-up. Drag on the arrow or type in a new value for the dimension.
    • m_youssef91
      Thank you very much, I did it
    • gwfeme
      I am new to Spaceclaim and I have entered a sketch of a rectangle.  I want to change the size of the rectangle.  This is trivial in Solidworks or NX but I can't access the dimensions of the sketch after I first enter it.  I have created the rectangle but didn't hit the space bar to actually enter the dimensions.  How can I edit the dimensions?
Viewing 5 reply threads
  • The topic ‘Editing a sketch’ is closed to new replies.
