June 20, 2023 at 8:21 pm
June 20, 2023 at 10:18 pm
peteroznewman
SubscriberOpen the geometry in SpaceClaim. On the Workbench tab, click the Share button. You should see all the edges that touch, highlighted to show they will be shared. After you click the green check mark, edges will be color coded for how many surfaces are sharing each edge.
Open the model in Mechanical. Most of the bonded contact is no longer needed so delete that. There may be only a few areas that need bonded contact or a Fixed Joint.
June 23, 2023 at 5:17 pm
e.zanelli3
SubscriberThanks for the response. Is there a similar function available through Design Modeler?Â
June 23, 2023 at 11:50 pm
peteroznewman
SubscriberIn DesignModeler, in the Outline, select all the surface bodies, right click and select Form New Part. That creates Shared Topology.
June 26, 2023 at 4:20 pm
e.zanelli3
SubscriberSo these two parts in questions are different thicknesses. Would that be a problem if I Form New Part?
June 26, 2023 at 11:03 pm
peteroznewman
SubscriberNo, each body can have its own thickness.
- The topic ‘Edge-to-edge contact issue’ is closed to new replies.
6760
1330
1097
