DynamicRomPreprocessing插件的问题
    • 2647595018
      ansys使用瞬态结构求解后无法用DynamicRomPreprocessing插件收集加速度的问题,按文档步骤操作后仍未解决。ansys使用版本2021R1插件使用版本DynamicRomPreprocessing_v5
    • Ashish Khemka
      Translated:
      ansys uses transient structure 求解后
      Cannot use DynamicRomPreprocessing plug-in to collect the acceleration problem,
      according to document step operation still not solved.
      ansys use version 2021R1 plug-in use version DynamicRomPreprocessing_v5
    • Romain Fichepoil
      Could you tell me the version of Mechanical you're using and the version of the plugins you loaded please?
    • 2647595018
      Mechanical为2021R1
    • Romain Fichepoil
      Ok I just advise you to use a more recent version or Workbench/Mechanical and DynaromPreprocessing plugin
      this should be fixed now
    • 2647595018
      您好,我已经使用了23R2版本的Workbench与DynaromPreprocessing。DynaromPreprocessing 还是只能收集图2中的Deformation而不能收集Acceleration,请问还有其他办法吗?还是说这个Acceleration根本无法收集,希望得到您的解答,感谢!
    • Romain Fichepoil
      Hi 腾飞 王, I will check it very soon
    • 2647595018
      您好,请问有检查结果了吗?
    • Romain Fichepoil
      Hi 腾飞 王,
      I investigated and found the way to fix it. Unfortunately I'm not allowed to share with you a former version with the correction. We will publish the 2024R2 version soon with the correction. I hope you can wait until it's published.
      Have a good day
    • 2647595018
      请问,2024R2版本什么时候发布
    • Romain Fichepoil
      It should be availaible the 10th of July approximately
Viewing 10 reply threads
  • The topic ‘DynamicRomPreprocessing插件的问题’ is closed to new replies.
