December 5, 2023 at 4:04 am
abankusomari
SubscriberGood day Sir. please i am modeling a magnetic gear of the below parameters to plot the dynamic torque plot of the inner and outer rotor but my plot is far from what i am suppose to obtain.please can some one help me fish out my mistakes.
The gear has 4 inner magnet pairs, 22 outer magnet pairs with different polarity and 26 steel segments .The thickness of the Permanent magnet is 6 mm.The air gap between the two rotors and the steel segments is 1 mm. The magnet material is NdFeb35 and the steel segment material is low carbon steel AISI1008 and the rotor yoke is ferromagnetic material.The inner rotor .The angular speeds of both inner and outer rotor is 150 rpm and 27.3 rpm.
my model is below
The position range for the dynamic torque is from 0 to 45 degrees. when i plotted dynamic torque of the inner and outer rotor ,my plot is below.
the actual plot was suppose to look like the figure below
December 7, 2023 at 12:05 am
GLUO
Ansys EmployeeHello,
The outter circle magnets pole seems like opposite from the first picture. Please double check if the poles are correctly defined.
GL
December 7, 2023 at 12:50 am
abankusomari
SubscriberOkay sir .please i will check that and respond swiftly.Thank you
December 7, 2023 at 1:00 am
December 7, 2023 at 2:30 am
GLUO
Ansys EmployeeIs the coercivity defined at radial direction correctly? Are you more worried about the phase or the amplitude?
December 7, 2023 at 7:11 am
abankusomari
SubscriberI am worried about the amplitude sir
December 7, 2023 at 7:15 am
abankusomari
Subscriberplease can you give me a snapshot on how to identify the coercivity in the ansys maxwell so i define it?
December 7, 2023 at 7:20 am
December 7, 2023 at 7:44 am
abankusomari
Subscriberfor the coercivity in the radial direction i assign 1 for north pole and -1 for the south pole
December 7, 2023 at 6:48 pm
GLUO
Ansys EmployeeYour picture shows it has an amplitude of 890k. Is the material coord cylindrical? R component should be -1 and 1. You also need to have the same correct permeability for all material in this model to get correct torque. Please use the support button at the left side of this page to submit a ticket for further help from our dedicated engineers.
GL
December 8, 2023 at 11:01 am
abankusomari
SubscriberThanks for your help Sir
- The topic ‘Dynamic torque plot of inner and outer rotor of a magnetic gear’ is closed to new replies.
5834
