October 22, 2018 at 9:59 am
Max4
SubscriberHi,
I´m trying to do this tutorial:
. Howewer I want to use a Profile instead of a UDF.
I have made the geometry and the meshing successfully.
Boundary Conditions: - Inlet: 0 Pa (Type Pressure)
                                   - Piston (Type Wall) and Settings by Default
Below you can see the Profile file. ".." is used in order to not writing all the components.
((piston1 transient 101 0)
(time
0
0,02
0,04
0,08 ..
1,98
2
(u
0
0,050636564
0,046777181
-0,004418245
-0,042826439..
0,008827861
0,058051301
The problem is that my velocity in all directions is 0.
Thank you.
Maxime
October 22, 2018 at 11:33 am
DrAmine
Ansys EmployeePlease check if you are running the case transient. Moreover check chapter 10.6.9.8. Solid-Body Kinematics to have the right format and specifications for your profile. Afterwards save case file and preview the mesh motion for verification purposes (Please save case file before doing that). For the profile use the specifications mentioned in the documentation (naming is important v_x, v_y, v_z,...).
November 2, 2018 at 1:24 pm
Max4
SubscriberThank your for your reponse. It has worked!
Maxime
July 10, 2023 at 9:51 pm
Muhammad Umair
SubscriberHello sir!
I have same problem in that module regarding valve and piston profile, plz help me that how to make it for ansys ic engine fluent
- The topic ‘Dynamic Mesh using Profile for Rigid Body’ is closed to new replies.
5649
1885
1404
1303
