September 17, 2024 at 7:41 am
federica.ongaro
SubscriberI am simulating the problem below: a moving wall (the right vertical wall) doing a horizontal translation (assigned constant velocity, rigid movement). All the other walls are assumed 'not-deforming'.
I used the Dynamic Mesh in Fluent, with the option 'Layering'. However, the mesh does not deform as expected; I obtain mesh elements very elongated and no new elements are created (as expected).
Coul you plese help me to solve this problem?
Thank you.
September 17, 2024 at 10:47 am
Forum ModeratorWhat did you set as a trigger to split the cells (ie add a layer)?Â
1891
1419
