April 8, 2024 at 9:48 pm
hatamimasoud68
SubscriberHiÂ
I am simulating a single-tooth gear pump with an upstream and downstream flow in ANSYS Fluent. I uploaded my geometry here. The thickness of my geometry is 0.02mm. I want to move the face and side walls of the gear throw domain. At first, I used the moving wall, but I received an error message that the direction of the rotation was perpendicular to the rotational axis, so I decided to use a dynamic mesh. I don't have experience in dynamic mesh.I consider the outer walls of the domain to be periodic. I think if I rotate the walls of the gear, it will crash into the periodic walls and diverge the solution. Is there any way to solve my problem???
April 9, 2024 at 9:23 am
Forum ModeratorPlease sketch out the whole domain. The image above doesn't make much sense for a CFD model.Â
April 9, 2024 at 11:36 am
hatamimasoud68
SubscriberDear Rob. I updated the geometry. Actually, this is the domain that first came to my mind. As you see, its a single domain where I tried to move the gear faces, but I couldn't, and it came with an error.
April 9, 2024 at 12:31 pm
Forum ModeratorOK, the gear is spinning inside a single cavity? No inlets or outlets?Â
- The topic ‘Dynamic Mesh in Fluent’ is closed to new replies.
5819
