October 4, 2023 at 7:37 am
Ryan Liaw
SubscriberHi, I am new to Ansys. I want to ask if the motion shown in the video below is possible with a dynamic mesh in Ansys Fluent and where can I get resources to learn how to do it if possible.
The fluid region would be as shown below.
I would imagine the fluid domain to look like this in its initial and final stage. The inlet is static.
Initial Top:
Initial Bottom:Â Â Â
Final Top:
Final Bottom:
I have seen examples of sliding mesh for 3D rigid bodies but all of them are rotating on their own axis through the influence of the fluid forces with 6DOF. I have also seen prescribed motions done with UDF in 2D.
However, I have not found any examples of prescribed motion done with a 3D model. If it is possible with the above methods, I would appreciate any links to resources that might help me make this possible.
Any help is appreciated.
October 4, 2023 at 12:18 pm
Federico
Ansys EmployeeHello,Â
You can find an example here to get you started  Ansys Fluent: Using the Six Degrees of Freedom (Six DOF) Solver - YouTube
For Dynamic Meshing, you can have any combination of prescribed motion in 3D or 2D and/or 6DOF.
Here, it seems to be that all motion is parallel with XZ plane:
- the direction of the rotation of the main disk is along the Y-axis;
- the direction of the rotation of the 2nd disk is along the Y-axis, with oscillation parallel to XZ plane;
- the oscillating motion of the arm is parallel to XZ plane.
Your would need 3 different DEFINE_CG_MOTION UDFs to characterize each of these movements. 2.6. Dynamic Mesh DEFINE Macros (ansys.com)
- The topic ‘Dynamic mesh help needed’ is closed to new replies.
5799
