January 23, 2019 at 3:35 pm
Max4
SubscriberHello,
I want to simulate the movement of the piston in black. Around the piston there is an inflation layer, which moves with the piston and set as rigid body in the dynamic mesh.
In the dynamic mesh zones, I set wall_p_1 and wall_p2_ as Deforming, and the simulation works well right down to the corner. The wall_p_1 belong to the inflation layer.
The problem is that I get negative cells in the corner (see the mesh below)
My question is, is this coming from the wall and the software doesn't understand that it has to continue? I want to have a situation like below.
Maxime
January 23, 2019 at 4:02 pm
DrAmine
Ansys EmployeeIs it possible to use "Deform Adjacent BL with Zone" for piston and using deform for the cell zone and walls?
January 24, 2019 at 4:06 am
Keyur Kanade
Ansys Employeethis looks tricky. i have not tried this anytime.Â
you may need to decompose the geometry so that you you have a wall_p_3 when piston goes up. wall_p_3 = wall_p_1 + wall_p_2 in your last image.Â
you may try with non conformal interface at wall_p_3.Â
January 24, 2019 at 7:36 am
Max4
SubscriberFor this simulation, I have used "Deform Adjacent BL with Zone" for the piston and Deforming for the cell zone (mesh) and walls.
I have tried to merge the wall_p_1 and wall_p_2 but it doesn´t work.
How can I create this wall_p_3?
January 24, 2019 at 8:32 am
Keyur Kanade
Ansys Employeeyou may need to do it at geometry level
January 24, 2019 at 8:59 am
January 24, 2019 at 7:17 pm
Raef.Kobeissi
SubscriberCoupled wall for heat transfer purposes?
January 28, 2019 at 2:39 pm
Max4
SubscriberHi,
I´m trying another approach, where the walls don´t overlapp. Let us consider the following system:
In the dynamic mesh setup, I have:
Piston - Rigid Body (UDF Piston)
Wall_p_1 - Rigid Body (UDF Piston)
Wall_p - Deforming (Layering?)
Fluid_around_wall - Stationary
Fluid_around_piston - Rigid Body
Fluid_around_wall_p - Deforming
Fluid_rest_domain - Deforming
- Around the piston (black), I have an inflation with 1 layer. I have an inflation around the wall (blue) too.
- Around the wall_p_2 (red) and wall_p (green), I have create another zone (in DesignModeler), in order to have quad cells on the wall
- The rest of the domain is composed of triangular cells
When I try to run this, I obtain the following situation. Inflation, which is supposed to remain fixed in relation to the piston, deforms. On the corner (picture 2), the inflation around the wall is deforming even if it´s as Stationary.
Maxime
January 28, 2019 at 3:44 pm
DrAmine
Ansys EmployeeThe answer to the original question would be to use non-conformal interface as you a topological change.
As the piston travels over the edge, the elements become negative. The only solution is to build a non-conformal mesh whose interface is a bit longer than the piston movement.Â
Without looking into the case will be hard to give any other suggestions here. As ANSYS Stuff we cannot download attachments and would not work on any cases. Perhaps one non ANSYS-Stuff can help you there.
January 28, 2019 at 3:55 pm
Max4
SubscriberThank you for your answer. I have extended the length of the wall_p and delete the corner in order to avoid the overlapping. The problem is that I have to have inflation or quad cells around walls for a better convergence of the solution and for the examination of the boundary layer.
I´m facing another problem with the movement of inflation which should be attached to the piston.
Moreover, I´d like that the quad cells attached to the wall_p deform (using Layering) according to the movement of the piston. The problem is that I cannot choose just the quad cells attached to the wall_p and then the wall_p and wall_p2 are moving at the same time.
Maxime
January 29, 2019 at 3:36 am
Keyur Kanade
Ansys Employeeas suggested in my previous postÂ
recommend you to us only tri mesh first. once you are successful with tri mesh then you can think of adding prisms. Â
January 29, 2019 at 8:05 am
Max4
SubscriberThank you for your reply.
I have understood, that I have to use non conformal mesh, but I´m not facing this problem yet.
The problem is the add of prisms around walls, especially along the wall_p.
I have separate the cells by shape (iso-value) and then seperate the shape composed of prisms in inflation around the piston or the wall. The problem is that all the prisms moves when I run a simulation.
January 30, 2019 at 9:00 am
Max4
SubscriberHi,
The system is as follow. I have separate the geometry in 3 zones in DesignModeler.
Green: Fluid_Remeshing - Deforming (Smoothing and Remeshing)
Orange: Fluid_prism_piston - Rigid Body
Grey: Fluid_prism_wall - Deforming (Layering)
The red line is the wall and I have set it as Deforming (Layering)
The black line is the piston and I hav set it as Rigid Body and it moves thanks to a UDF.
When I run a preview mesh motion, the Layering on the Fluid_prism_wall (grey) doesn´t work and I don´t know why.
Maxime
January 30, 2019 at 10:30 am
Keyur Kanade
Ansys Employeethe prism on left side walls will not be remeshed.Â
please remove prism on left side wall.Â
January 30, 2019 at 10:41 am
Max4
SubscriberWhy can't these cells be remeshed with Layering?
I have to keep this prism cells on the wall in order to guarantee a better convergence of the solution and for the examination of the boundary layer.
January 30, 2019 at 10:48 am
Keyur Kanade
Ansys Employeethen you have to have that cell zone as different than tet. also there should be non conformal between tet and quad. then you can use layering for quad and remeshing for tet.Â
please try without prisms on left side wall and check how it goes.Â
January 30, 2019 at 11:05 am
Max4
SubscriberI have created 3 zones in DesignModeler. Then I created different cell zones in Fluent using Mark/Adapt and Separate.
 I used Layering for the cell zone along the wall, and Remeshing + Smoothing for the cell zone with tet cells.
January 30, 2019 at 12:19 pm
Keyur Kanade
Ansys Employeeyou need to have non conformal between left side prism and tet
January 30, 2019 at 2:24 pm
Max4
SubscriberShould I do it in Fluent or in Meshing ? I have found this: http://www.afs.enea.it/project/neptunius/docs/fluent/html/ug/node189.htm (Using a non-conformal mesh in ANSYS Fluent).
The bold green line is the interface between prism cells along the wall and the tet cells, but it´s set as Interior and I can´t change it as Interface.
In DesignModeler, I have grouped the different bodies in 1 part, so that Fluent knows that all parts represent the fluid.
For create the different zones in DesignModeler, I used in Operation "cutting material". Is it better to use "Add frozen" or "Add material"?
Maxime
January 31, 2019 at 9:06 am
Max4
SubscriberHi,
I have created an Interface (in yellow) in ANSYS Meshing (picture 1). Then I have separate the prism cells (rper:015 and rper:005) along the wall on the left side (picture 2).
The fluid should cross this interface, thus what Option should I use in Mesh Interfaces in Fluent? Should I create 2 Interfaces, one for each zones ?
Maxime
February 4, 2019 at 5:28 am
Keyur Kanade
Ansys Employeethere should be interface between left side prism and bottom prisms
February 4, 2019 at 7:18 am
Max4
SubscriberWhen I have created it, what should I apply to this interface?
February 4, 2019 at 7:21 am
Keyur Kanade
Ansys Employeeyes, you should apply interface.Â
February 4, 2019 at 7:34 am
Max4
SubscriberI should apply "Interface" as Type, and then should I still done anything else?
- The topic ‘Dynamic Mesh – Deforming Wall’ is closed to new replies.
