October 28, 2021 at 10:45 am
Bibill
SubscriberDear all,
I'd like to reproduce a dynamic mesh adaption methodology introduced in the conference proceedings Dynamic Mesh Adaptation for Scale-Resolving Reacting Flow Simulations (2021) - Yu Xia et al. (Ansys).
In the present paper, they impose a refinement/coarsening of the mesh based on the LES index defined in equations (2,3,4) with the conditions (6a,6b).
October 28, 2021 at 12:29 pmaitor.amatriain
SubscriberYou can access to the value of velocity components at the previous time step
3.2.3. Cell Macros (ansys.com)
so the mean value is obtained from the definition. The same applies to I.
October 28, 2021 at 1:09 pmBibill
Hi Aitor, thank you for your fast answer.
If I understood well, is the mean velocity component obtained by averaging over 2 time-steps then?
October 28, 2021 at 1:37 pmaitor.amatriain
SubscriberNo. Let's say that you have simulated n-1 time steps. Then, the mean value of a variable called U is:
The value of the previous expression is known, so the mean value of U at t=t_n is:
In fact, you do not need the values of the variables the previous time step. You only need to create a Custom Field Function/UDM to then rewrite the value at each time step.
October 28, 2021 at 2:49 pmBibill
SubscriberOk, great I understood! Yes, indeed we do not need the previous time step value then!
Thank you very much, Aitor!
October 29, 2021 at 6:47 amaitor.amatriain
SubscriberYou are welcome!
Viewing 5 reply threads- The topic ‘Dynamic Mesh Adaptation : SBES’ is closed to new replies.
5654
1890
1414
1304
