January 11, 2023 at 9:34 pm
Santu Golder
Subscriber -
January 12, 2023 at 10:45 am
Prashanth
Ansys EmployeeHiÂ
DEFINE_CG_MOTION can be used. You can also check a example case in the UDF manual.
January 12, 2023 at 5:31 pm
Santu Golder
SubscriberNA
January 13, 2023 at 12:19 pm
Prashanth
Ansys EmployeeSure, you can use if and else to limit the motion
January 17, 2023 at 6:26 pm
Santu Golder
SubscriberNA
January 18, 2023 at 1:32 pm
Prashanth
Ansys EmployeeHi, Can you check out this dynamic mesh robotic arm tutorial that uses something similar:
January 18, 2023 at 8:51 pm
Santu Golder
SubscriberNA
May 11, 2023 at 3:58 pm
Santu Golder
SubscriberUDF Error:
Hi Prashant, Can you please tell me how I can handle the following error in Fluent? I am using ANSYS Student version.
ERROR: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).
The system cannot find the file specified.
Viewing 7 reply threads
- The topic ‘’ is closed to new replies.
