3D Design
3D Design
dxf dwg step filetype association with SpaceClaim
    • Andrea Ventura
      I want to use normal double click on file to open dxf, dwg and step file with SpaceClaim. Old version allowed it in a very simple way (open with association). Named user license seems to have problems to do it.
      How to solve? I think I should modify windows enviroment variables and/or register, but don't know how.
    • Devendra Badgujar
      In the Windows registry look at this key and make it correctly setup like the value shown below:
      Go to this location:
      HKEY_CLASSES_ROOT\SpaceClaim.Document\Shell\Open\command
      The value should be set to "C:\Program Files\ANSYS Inc\v231\scdm\SpaceClaim.exe" "%1"  "/USERUNNINGSPACECLAIM=true" "/UseLicenseMode=true"
      Devendra
    • Andrea Ventura
      I solved in Explorer, but when open a file in Thunderbird it ask me how to open and if I select SpaceClaim the problem still remain.
    • Devendra Badgujar
      Windows it works right? What is thunderbird?
