September 17, 2025 at 8:25 am
September 18, 2025 at 11:33 am
Ivonne Marti
Ansys EmployeeHi,
If you want to introduce this type of stator teeth geometry, please use Maxwell. From RMxprt, you can automatically create a Maxwell model, where you can make the necessary geometry modifications to design the tooth shape you need.
Ansys Innovation Space
- Y wiring method and the start and end points of winding.
- Lumped Port Deembed
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- Hfss 3D pcb via capped and filled with epoxy
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
1414
1241
1118
1015
