November 28, 2023 at 1:38 am
yipxx043
SubscriberHello,
I have ran the Shock Bubble Interaction (+FSI) (+3D) case here from the dynaexamples.com website here (https://www.dynaexamples.com/cese/dualcese/shockbubblefsi)Â
How do I best visualize this? I see the animated gifs, but not sure how those were obtained.Â
Thanks,
Peter
November 28, 2023 at 7:32 pm
Alex Rycman
Ansys EmployeeHello Peter,Â
The animations that you are seeing were obtained using LS-PrePost. You can download it from the Ansys web site https://lsdyna.ansys.com/download-install-overview/ . For processing multisolver models MSPost Explorer in LS-PrePost is used (upper ribbon View -> MSPost Explorer). There you will be able to see your parts and choose a desired fringe in Display Option card. Please see figure below.Â
Please let me know if it worked.Â
Thanks,
Alex -
November 28, 2023 at 8:23 pm
yipxx043
SubscriberHi Alex,
Thank you. That partially worked. Since it's in 3D, I want to slice down the middle so I did this operation: Model -> Section -> NormY and it doesn't show the contour down the slice. How do I slice and still see the contour?Thanks,
Peter
November 29, 2023 at 1:38 pm
Alex Rycman
You could slice the model by blanking half of the model. Would that work for you: Element Tool -> Blank -> Area?Â
Thanks,
AlexÂ-
November 29, 2023 at 1:41 pm
November 29, 2023 at 6:22 am
Ushnish Basu
Ansys EmployeePlease ignore this post :-)
November 29, 2023 at 1:36 pm
yipxx043
SubscriberHi Ushnish,
I am not sure if you're saying to ignore only your post or this entire thread entirely? I still would like the ability to see contours along the plane I slice in 3D?
Thanks,
Peter
November 29, 2023 at 4:27 pm
Ushnish Basu
Ansys EmployeePeter,Â
I had posted essentially the same answer as Alex before refreshing the page, so I deleted it. Alex will help you further.
Best,
Ushnish
- The topic ‘DUALCESE Visualization’ is closed to new replies.
5809
