March 23, 2023 at 5:22 am
tim.dukes
SubscriberHi support does Discovery support two graphics card. I know you can't use two graphics cards at once but if two are installed on a PC can Discovery specify which one to use? Â In the past there has been an issue and I am wondering if this is still the case. Â The reason I ask is because a customer has SW 2019 and the graphics card they are using for Discovery isn't compatible with SW 2019. Â Currently they are having to swap out the graphics card each time they want to use the other software. Â If the PC can have two graphics card you can specify in the Nvidia control panel that Discovery uses that graphics card and SW uses the other. I am just wondering if you know if this would cause an issue? -
March 23, 2023 at 6:52 am
Subashni Ravichandran
Forum ModeratorHello Tim Dukes
I'm not aware if having 2 GPU but using one of two graphics was an issue for Discovery. I think it should not be problem.Â
Please follow the instructions on this page to assign one of multiple GPUs on the machine to Discovery.
- The topic ‘Dual graphics Cards Ansys Discovery’ is closed to new replies.
- Add-in Error Excel
- Missing SubDivWrapper.dll
- Fileformats
1487
1318
1156
