May 16, 2024 at 7:21 pm
Ömer Öksüz
SubscriberHi everyone, i would like to model a hot air drying process of a spherical fruit which contains certain amount of humid inside. What model should i use and how am i supposed to approach such a problem, please help me out by some guide, appreciated.
May 17, 2024 at 10:33 am
Forum ModeratorI'd approach this very carefully. Do you need to model inside the fruit or can you look at the environment and use a hand calculation for moisture diffusion in the solid?
May 19, 2024 at 6:02 pm
Ömer Öksüz
SubscriberThank you for your reply, i would like to have results of moisture and temperature distrubition inside the solid object at the end of drying process. I think the second option(hand calculation) will be easier, but otherwise for first option, would it be possible ? or what would you recommend and proceed ?
May 20, 2024 at 10:43 am
Forum ModeratorIt's possible, but you'll need so much information on the fruit material that it's not going to be a very simple model.
May 20, 2024 at 11:37 am
Ömer Öksüz
Subscriberokey then let's say i will go for hand calculation, in this case would you guide me in detail for modelling process.
May 20, 2024 at 1:17 pm
Forum ModeratorFor the outer flow field you need to find temperature & local speed. That'll assist in obtaining the drying rate into the outer domain. Re the rest - please talk to your project supervisor!
May 20, 2024 at 2:11 pm
Ömer Öksüz
SubscriberI am not asking for theoretical assist here, just please guide me about modelling process in fluent, what should be the fluid flow model
Sould i use multiphase if so what mechanism should it be ? Thank you.
May 20, 2024 at 2:40 pm
Forum ModeratorFor the bulk flow domain I'd use single phase and potentially not bother with species or energy. It depends on what information you need to include in the drying model. You need to define what you need the CFD for and what you intend to do via the hand calculations, and also what data is needed from the CFD model to feed the hand calculations.
- The topic ‘Drying of a sphere shaped moist fruit’ is closed to new replies.
5964
1307
