Drying Fruit Process
    • taso_ph
      Hello.
      I am currently working on drying fruits using Ansys Fluent. However I still need guiding on the topic. My question is when I add a solid material from the database, in cellzone or boundary conditions seems like I cannot use the solid material. Can you please explain it ? I am right now trying to make a multiphase model on the drying process.
      Thanks in advance, kind regards.
    • Karthik Remella
      Administrator
      Hello:
      Under cell zone, have you changed the type to Solid? Once you do that, you should be able to use the solid material you added.
      Karthik
      To add, if it's a solid then you can only model heat transfer. If you're drying something you may want to look at porous media.
  • The topic ‘Drying Fruit Process’ is closed to new replies.
