October 8, 2023 at 3:01 am
Finn Blake
SubscriberHi,
I am injecting a solid cone of evaporating droplets. I have set the rosin rammler distribution with 1.5e-5m, 6e-5m, 7e-5m for minimum, mean and maximum. At the near injection zone the SMD follows this but the diameter doesn't. However further downstream the the SMD and the diameter both grow to significantly larger. They shouldn't be doing this and I'm not sure why/how to stop it.Â
Any advice appreciated.
Thanks
October 9, 2023 at 8:59 am
Forum ModeratorHave you got any other DPM models switched on?Â
October 9, 2023 at 11:07 pm
Finn Blake
SubscriberHi Rob, I have the one solid cone injection and within the DPM window I have pressure dependant boiling and breakup turned on (breakup with KHRT). Also just to add I'm using 2021R1
October 10, 2023 at 8:53 am
Forum ModeratorAny coalesence?Â
October 10, 2023 at 9:39 pm
Finn Blake
SubscriberThat appears to be what is happening just by looking at the graphs but I don’t have stochoastic collision turned on (which is where coalesence would occur) so I don’t think that should be the case.
UPDATE: If I turn off breakup this problem doesn’t seem to occur and the droplet diameters are as predicted. However the velocity profile means the spray doesn't hold its cone shape as only the particles heading in the z direction have high velocity and the rest of the cone is significantly lower, it is like this:
Is there a setting so that the velocity is more evenly distributed in the cone so it holds its shape instead of the central core dominating it like that?
Thanks
October 11, 2023 at 8:42 am
Forum ModeratorThe droplet trajectories are also influenced by the flow. So, for a cone I'd expect the angle to collapse in a co-current flow, or one assisted by gravity.Â
Replot the above by age and velocity component (left-right coordinate) and the image may be clearer.Â
October 11, 2023 at 9:23 am
Finn Blake
SubscriberYep thanks Rob, that makes sense. Do you have any idea why including the breakup model is causing the droplet sizing to be wrong?Â
October 11, 2023 at 1:47 pm
Forum ModeratorCan you open the DPM Numerics up and check the panel(s)? I remember that activating break up automatically turned coalesence on which you could then switch off.Â
October 11, 2023 at 8:47 pm
October 12, 2023 at 12:37 pm
Forum ModeratorOops, Physical Models. Sorry!Â
October 12, 2023 at 7:30 pm
Finn Blake
SubscriberI didn’t have coalesence in there either, it only shows up as an option when collision is turned on (which I did do just to turn coalesence off and than collision off again). I actually have narrowed it down to the KHRT breakup being unsuitable for the spray, If I use the TAB model than the diameters are correct so I appear to have solved it. I was using the jet weber number instead of droplet weber to decide which breakup was suitable but I think given my spray in a real scenario begins as a disperesed 2 phase flow I needed to use droplet weber number. Thanks for your help
- The topic ‘Droplet diameters are larger than the diameter distribution I specified?’ is closed to new replies.
5694
1891
1419
