TAGGED: cfd-microfluidic, droplet-behaviour, Explicit-VOF
September 16, 2025 at 2:49 am
subra284
SubscriberHi!
I am trying to simulate the break-up of droplets in a microfluidic domain using Fluent, and could not get droplets to break. I was wondering if there is an option in Fluent to determine the break-up criterion, i.e. an option that says something like, "if the diameter of the droplet getting squeezed through a constriction falls below a threshold diameter, you should break it off."
Please let me know. If you can suggest any alternative strategies, that'd be great, too.
Thanks,
Abhishek
September 16, 2025 at 7:52 am
Forum ModeratorIf you're using DPM then don't and read how it works. If you're looking at VOF, droplet break off will be a function of flow, but as surface tension forces dominate and you'll have very small cells it's a nontrivial application to model.Â
- affinity not set
3867
1414
1241
1118
1015
