TAGGED: Ansys Discovery, assemblies, assembly, input-parameter, joint, parameters
March 19, 2024 at 5:35 pm
brendan
SubscriberI am wondering if anyone has been able to set the angle of a crank in an assembly with a parameter driving the rotation.Â
I have a dual crank mechanism that I would like to simulate in a few different positions. Angle 1 of crank relative to bearing housing, and angle 2 of crank 1 relative to crank 2.Â
Is this possible with Discovery/Mechanical? Seems like it should be rather simple to setup but I cant seem to find a way to bring in those rotation parameters.Â
I have tried using part transforms in Mechanical, but that only rotates one part at a time, and doesnt maintain the assembly constraints applied in Discovery. Ive also tried setting up revolute joints in Mechanical, but the positions of those joints are also not maintained during part transform.Â
Any help is greatly appreciated. -
March 26, 2024 at 11:46 am
Ashish Khemka
Forum ModeratorHi Brendan,
Part transform will help to modify the orientation in Mechanical. Can you see the parametrize option for the joint loads like rotation or may be setup an analysis with multiple steps indicating different orientations.
Ashish Khemka
- The topic ‘Drive the rotation of a crank with parameters in Discovery / Workbench.’ is closed to new replies.
3567
1103
1063
1045
947
