June 12, 2020 at 12:39 pm
charles.agbaje.ph.d180001
SubscriberI want to draw a cylindrical pressure vessel using spaceclaim and i cant find my way around it and even all the tutorials I checked are not doing it .Please kindly help
Charles
June 12, 2020 at 1:56 pm
Naresh Patre
Ansys EmployeeHello Charles
A cylindrical pressure vessel can be thought of as a cylinder with both ends having a shape of hemisphere or similar curved faces. So you can first the sketch the outer half profile and then pull-rotate around its axis to generate a 3d model. Later on, you can add the openings, stand, and other relevant features. See below.
If you have access to Discovery AIM, you can download the pressure vessel example from below link and check out the model in that example.
June 15, 2020 at 10:38 am
SubscriberThank you very much sir. I will try this option and get back you sir.Â
- The topic ‘Drawing Pressure Vessel’ is closed to new replies.
- Add-in Error Excel
- Fileformats
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
- Inconsistent Script
4597
1500
1386
1209
