Electronics
Electronics
Drawing different shape.
    • abidahmad2020
      Dear Concern, i wanted to draw a U shape in HFSS, AT FIRST, I did draw 3 poly line and by selecting two vertex and did use fillet, but i wanted to give this shape like 3 d shape. I am wondering if anyone could tell me the step to do that. Thank you.
    • slouie
      First select the CreatePolyline command in the history tree:
      In the Properties window, change Cross-section Type from "None" to whatever you would like the cross-section to look like and enter in details about cross-sectional dimensions.
    • abidahmad2020
      Dear sir, i know this things, but it does not work when i do fillet, let me tell you what i did.
      I did draw 3 polyline first.
      Now, Right click>>Selection mode>>vertex
      And select 2 vertex, Then use Fillet.
      Now, after Fillet, if i wanted to change the "cross section type", it does not give me the 3 D shape. Please answer me here. Thank you
    • slouie
      Please try changing cross section and then adding chamfer or fillet. You may not even need to do this as you have the option for "Bend Type" = Rounded once you've added cross section type to the polyline.
    • abidahmad2020
      Yes, I also did that using "Bend Type" = Rounded, but this does allow me to get exact curve i am trying, because we can not vary it. Could you check please. thank you
    • slouie
      If you need to parameterize the bend, rather than using rounded bend type, then please try fillet operation after adding cross section.
Viewing 5 reply threads
  • The topic ‘Drawing different shape.’ is closed to new replies.
