Electronics
Electronics
Drawing a coil
    • ericwu
      Hi, everyone:
      I'm drawing a coil with rectangle cross section in Maxwell, I didn't import the CAD model since I need the coil be parametered.
      I used "sweep along path", while the coil "twisted" with non-regular pattern as the pictures below.
      Is there any way to build a coil which each layer of sections are aligned or parallel?
      Thanks!
    • NKC
      you can use the inbuilt UDP operation for this.
      See the below screenshot. After you select the rectangular helix you will see a popup window with variables. You can enter the values as needed and click OK.
      Regards Navya
  • The topic ‘Drawing a coil’ is closed to new replies.
