Drag coefficient of droplet (DPM)
    • jaded_messiah
      Hello there! I have DPM simulation of single droplet falling in the pipe. To check the result i want to know drag coefficient or at least drug of this droplet. The problem is - i know how to check drug only on the geometry (body or surface) but DPM droplet is not geometry =( I can see droplet's Reynolds number and find drug coefficient in the directory to compare it with simulation.
    • DrAmine
      You can calculate the coefficient based on the particle variables or write UDF to code that coefficient and store it directly.
  • The topic ‘Drag coefficient of droplet (DPM)’ is closed to new replies.
